- 5:35 PM
- Jan 17, 2016
- Wv
Are they outlawed like straws are?Nope haven't touched a saw in 2 weeks. Maybe soon I will though.
Lol no not yet. Heck where I'm at straws aren't a problem just yet.Are they outlawed like straws are?
Looks like I'll be doing about all the firewoodLol no not yet. Heck where I'm at straws aren't a problem just yet.
You need a catEvening fellas. Been racking my brain to figure out the best way to get the ceiling put up around all this mess.
Tonight I think I've decided to eliminate most of the bracing you see here. There's no side load on the garage door track so I see basically zero reason to keep it.
Suggestions, thoughts??![]()
But I don't like them...[emoji38]You need a catView attachment 147833
Looks goodEvening fellas. Been racking my brain to figure out the best way to get the ceiling put up around all this mess.
Good evening bish. That's a tough call on the bracing. Sure would suck to have something go wrong.Evening fellas. Been racking my brain to figure out the best way to get the ceiling put up around all this mess.
Did you ever get your stove set up?Looks like I'll be doing about all the firewood
For my niece and husband
He hurt his back a few month's back.
My saws need run anyway
Evening Mikey. I think I'll remove the four long angled braces and tie the two drops in the center together a little better. The short braces on the outside should be enough to eliminate any lateral movement there.Good evening bish. That's a tough call on the bracing. Sure would suck to have something go wrong.
Meh..got three just like him.
Could put them back up after the ceiling is up if you wanted to. Just a idea is all, and no promise it's worth a chit lol.Evening Mikey. I think I'll remove the four long angled braces and tie the two drops in the center together a little better. The short braces on the outside should be enough to eliminate any lateral movement there.
Just kinda thinking it over before tearing it all out.
Thought about that too. Or switch it out for angle iron if needed.Could put them back up after the ceiling is up if you wanted to. Just a idea is all, and no promise it's worth a chit lol.
Angle iron mo betta lol.Thought about that too. Or switch it out for angle iron if needed.
That's what I'm thinkin'.Angle iron mo betta lol.
