Status
Not open for further replies.
P.M.P.
Stiff Member
8:21 PM
Michigan
Here for the Yum Yum Sauce
7:21 PM
Top of the Mornin guys
Thanks Ray
They have a list for uses comes in handy just what I was wantin. Yesterday changed out a tie-rod used this grease when I was screwing it deep. Then did my redneck alignment. Things tip top now can ride rails its so straight.
What is that grease like, is it tacky and so on.
P.M.P.
Stiff Member
8:21 PM
Michigan
I really like it different not sure about tacky but seems to hold real well when applied.In the desciption says it resist flying off at high speeds,chemical washout,0-300 working temp,excellant corrosion resistance. It's great to know more about it.
7:21 PM
I really like it it's different not sure about tacky but seems to hold real well when applied.In the desciption says it resist flying off at high speeds,chemical washout,0-300 working temp,excellant corrosion resistance. I really like it great to know more about it.
I like that it's in a squeeze tube, would be handy to have one on the work bench for assembly and such. Drum bearings come to mind as a handy use.
7:21 PM
7:21 PM
Hey your pretty fast fart smeller you are.Beat me reply you did.
Bought a tube, if nothing else I can put some on my Avatar...
When I looked it up a little while ago, I ran across a couple of eBay links that have it but didn’t open them...maybe old ads though.
Gunner's link is good and he has more, probably Surplus I would guess.
Status
