Did you turn it sideways? It was always the sideways balance that was questionable...
Inboard clutch = automatic fail.
The echos were fine yesterday. The huskies, however were all tipped over in the truck. They must be top-heavyDid you turn it sideways? It was always the sideways balance that was questionable...
I did all sorts of wrenching yesterday..The echos were fine yesterday. The huskies, however were all tipped over in the truck. They must be top-heavy
Would've been better if some cork soaker brought you a fast chain. I'm sorry again JoeI did all sorts of wrenching yesterday..
Swap this bar.
Change that chain.
Short bar. Longer bar.
Square chain.
7 pin.
8pin
Carb
Coil.
Slow and steady Hehehe
Fell asleep, now headed to rhe rack. Night. [emoji38]Good evening Rodney. How are you doing tonight?
I'm not at all worried bout the chain Kevin.Would've been better if some cork soaker brought you a fast chain. I'm sorry again Joe![]()
Swap this bar.
Change that chain.
Square chain.
7 pin.
8pin
Carb
Coil.
Fix and afford are two different words. They are way down on the list for replacing.Drive that bish through the door. We all know you can fix it lol.
I did learn some things. I like the dolmar fuel filters. Completely serviceable. Take it apart, couple shots of air and carb cleaner and this one was back to new. And theyre weightedI'm not at all worried bout the chain Kevin.
Was poking fun at the other wrenching activities going on yesterday. Stupid filters, fuel lines etc... Nature of the beast tho.
That sure is nice.I did learn some things. I like the dolmar fuel filters. Completely serviceable. Take it apart, couple shots of air and carb cleaner and this one was back to new. And theyre weighted
Cus had some buns. We ate well. ThanksThat sure is nice.
Sorry I forgot to leave the buns foe the brats... probably would have been the cats meow with them pickles...
TittiesBeen a rough afternoon and night. I get in these ruts, and I can’t seem to make heads nor tails about nothing....I wouldn’t wish my travels nor life on a single MFr.
Keep your head up! And look on the bright side at least your not at the ATL airport with no power.
