Status
Not open for further replies.
nickw
A Legend in my own mind
9:30 AM
Fletcher, OK
Things just seem so convoluted right now guys. I gotta be strong and be the man, the Marine, for my kids. And I will not fail them...but my head hurts and it ain’t right. Thank you all for the kind words. I’ll be back...you can bet your asses on that! I’ll be back!
Just keep posting occasionally so we can be sure you're all right.
Time's Standing Stihl
Below me...
10:30 AM
Central Iowa
If you don't have anyone to talk to. Feel free to pm me and I'll give you my number. We can talk about pussy, hunting....Hunting pussy, guns...saws, whatever the fug you want.
Stay strong brother
nickw
9:30 AM
Fletcher, OK
Stay strong brother
We could talk about your friend with the sculpted 44Ds that you never posted a pic of.
9:30 AM
Good afternoon, 'nother day an da roof one more to go...
Wayne here is a short clip of my finger smasher.
Just a foot pedal.
Ain't putting my fingers close lol
Sure makes short work of it and I'd keep using the pliers. Lol
562 mod. One to let air out for hot start issues (never had,but don't want) and other to let more air in the filter
Clint, check to see your cover isn't just blowing/ bleeding off cool air that otherwise could/would have went by the motor, could have a reverse affect otherwise.
Below me...
10:30 AM
Central Iowa
Guess I don't see it that way Steve. Just like water or air. ...heat rises. If that was the case, Husqvarna wouldn't of made a different version of the top cover to let hot air out. Maybe I'm wrong?
Look at this pic, the triangle cut out is from the factory. Wasn't like that the first couple years...
9:30 AM
Yes, the side the triangle is on the air has already went past the motor from the fan. The side you put the frog skin on is the fan side, so if it leaks out(while running) you will be loosing cooling capacity while running.
Below me...
10:30 AM
Central Iowa
Fan should push it on out then [emoji6]
leadfarmer
Hot Rod !!!
10:30 AM
S Central PA
It's just a hooskie Stumpy [emoji38]
Below me...
10:30 AM
Central Iowa
Don't think of your hot start, think of it while it's running, if air is pouring out of that frog skin, it's not cooling your motor.
So cool air travels from the flywheel up and out the frog skin but it won't cool as it goes by the fins?
I'll let you know if or when I'm wrong
Status
