- 3:50 PM
- Jun 5, 2016
- Northwoods of Wisconsin
Mine must be older, it does not have that funky brake. Probably the problem.
My guess is thats the faulty parthttp://www.ebay.com/itm/STIHL-CHAINSAW-020AV-CLUTCH-BOX-1260N/352039586224?_trkparms=aid=222007&algo=SIM.MBE&ao=2&asc=46089&meid=6cf112393a074340bb13140874b128d8&pid=100005&rk=2&rkt=6&sd=131383800206&_trksid=p2047675.c100005.m1851
http://www.ebay.com/itm/OEM-Stihl-0...nbrake-Drive-Disc-1114-162-3600-/131383798940
@leadfarmer looks like it has a disc drive along with the clutch so the disc drive drives the clutch and in turn drives the chain
I did that an at that point the clutch is engaged an spinning
So it should rev up the same with break engaged?Then the brake mechanism in the cover is not disengaging.
I don't know we was hoping you had worked on one@dall, those brake covers have a procedure for resetting them?
the disc drive is probably slipping and not giving power to the clutch and why you can rev it up and no chain spinSo it should rev up the same with break engaged?
see you in about 4 hours lolI have, but it is a different style. Trying to dig out a manual now.
it will take steve time to find what hes looking for lolYou on the road?
Hahaaa. Well I'm headed to the shower then. Check back after bit [emoji38]see you in about 4 hours lol
Evening fellas, taking carrie on a date
Sent from my SM-G900R4 using Tapatalk
with picturesCop a feel for me. Lol
