- 5:24 AM
- Feb 5, 2016
- grafton wv
night dave
Cleaning up a log landing. Time to start filling the wood shed...Good been dropping small tree's to make a landing for some big dead ash.
I will have unlimited firewood lol
What are you working on.
I'm thinking the occasional small concrete removal job. I have access to a dump trailer. Rather than pay an excavator, I can do some of it myself. Also be nice for grabbing logs off the groundMight be a bit rough on the cement blocks. Pretty nice though Kevin.
Have a goodern buddy.Bedtime fellas. Yall have a good night
yes you will use it alot more than you think and youll ask yourself why you didnt have one beforeI'm thinking the occasional small concrete removal job. I have access to a dump trailer. Rather than pay an excavator, I can do some of it myself. Also be nice for grabbing logs off the ground
Those things are awesome Kevin. Do you already have the third function on your loader?Evening fellas.
I'm ordering one of these tomorrow. It'll be nice to have for work plus it'll help for firewooding
That'll be nice. I'm not a fan of brush cleanupthey are the berries for brush cleanup also
What's shakin turd bird?yes you will use it alot more than you think and youll ask yourself why you didnt have one before
not much and concealed unlike maulheadWhat's shakin turd bird?
i want bars that last more than a year the green forester crap was 2 months
Yeah it's got it. It's an L48 Kubota. They all come with a frame-mounted qd backhoe and has 3 pt arms that take about 5 minutes to put on. I had an old wood splitter that ran like crap. I cut the axle and motor pan off it and converted it to run off the front quick detach mount and front aux hydraulics.Those things are awesome Kevin. Do you already have the third function on your loader?
That's perfect then. Saves you a little bullchit not having to add the third function.Yeah it's got it. It's an L48 Kubota. They all come with a frame-mounted qd backhoe and has 3 pt arms that take about 5 minutes to put on. I had an old wood splitter that ran like crap. I cut the axle and motor pan off it and converted it to run off the front quick detach mount and front aux hydraulics.
I like to keep some of them erasers around in case I make a mistake with my pencil...Possibly?View attachment 80775
The front pump is only 12gpm. But the splitter only has a 3" cylinder for now. It won't split big stuff in half, so I just take a 3 or 4" slab off and rotate, repeat. 3.5 second cycle time at 1500 rpm though lolThat's perfect then. Saves you a little bullchit not having to add the third function.
A friend of mine did that to his splitter but his little JD doesn't have balls enough to run it. Lol
