- 2:32 AM
- Oct 18, 2016
- GFY
Hey the first step is admitting it.Story of muh life
My first time wasn't so good either. I'm sure you will get the hang of it.No I have a couple. I tried last night for the first time. To say I failed is an understatement
I cane even figure out how to get the file at an angle to fileMy first time wasn't so good either. I'm sure you will get the hang of it.
Looks good! But I would eat it all of it you need more lol.Dinners up..![]()
Have you checked out the square file thread Dave? That's what really helped me out.I cane even figure out how to get the file at an angle to file
I have a couple square chains but didn't want to mess them up. The one I was practicing on was a stihl square chain and cannot figure out the angleDave I can send you a chain to play with
I've skimmed thru it a littleHave you checked out the square file thread Dave? That's what really helped me out.
Hold the file to where it's touching on one of your good square chains. Then look at those angles, and try it on the chain your working on.I have a couple square chains but didn't want to mess them up. The one I was practicing on was a stihl square chain and cannot figure out the angle
You need Kevin and Mike Lee for pointers, cause I'm far from as good as they are.I've skimmed thru it a little
May have to take a trip back up to MikesYou need Kevin and Mike Lee for pointers, cause I'm far from as good as they are.
Ok guys ,i have some technical ????
Messin with 031av with points.
Converted to nova 2 electronic.
I have spark and fuel but wont run.
Have been told wont work need different flywheel ?
So where does the flywheel need to be for timing with piston TDC ? As far as pickup on flywheel in relation to coil?
If they are different ,points vrs electronic, then I could take off key and position where I need it correct?
I'm thinking that would be the best bet, and I wish I was close to him.May have to take a trip back up to Mikes
Good evening Steve, how have you been doing?You should NOT need a new flywheel. Has to fire in the same place whether points or a module are doing the job. If you convert to a modern Stihl modulated coil then you MAY have to change the flywheel. Not with the NOVA II. You say you have spark, but do you have good spark? By this I mean will it jump an air gap of say 5mm and be a bright blue color and snap right across? If not the problem is most likely a weakened coil. One other thing make sure the ground from the module is being grounded out at the coil, not somewhere else on the motor.
