- 12:30 AM
- Dec 31, 2015
- East Jordan, MI
Good deal Dave, so it sounds like you had a great day.Good evening fellas just got home. I now have a built hybrid.
That stupid nwp cylinder is ridiculous. Base gasket delete and the squish is 41. Nate asked what I thought the psi was. I said 160, came out to 163ish
I snagged a stock cylinder. Is there a difference in the jug itself from 7900 to 7910? Wanted to think one of the pistons is windowed and the other isn't?
Sure did. Even got to fire it up and run a couple heat cycles thru it. Hopefully I'll be able to put it in wood tomorrow after work.Good deal Dave, so it sounds like you had a great day.
I can take some off if you want. Does it have a windowed piston or slab side? I think a slab is a little betterThat stupid nwp cylinder is ridiculous. Base gasket delete and the squish is 41. Nate asked what I thought the psi was. I said 160, came out to 163ish
The nwp piston is windowed.I can take some off if you want. Does it have a windowed piston or slab side? I think a slab is a little better
7910 piston is slab. No windows. There's also a bump in the exhaust floor in a 7910I snagged a stock cylinder. Is there a difference in the jug itself from 7900 to 7910? Wanted to think one of the pistons is windowed and the other isn't?
Doing great Dallas how about youevening dave hows you
Yes sir! Thank you again for answers all my questions
Any problems Dave? Everything go together easy?Sure did. Even got to fire it up and run a couple heat cycles thru it. Hopefully I'll be able to put it in wood tomorrow after work.
I mean. ...hi. sorry
Azz pirateHomo
7910 piston I heard is better? Lighter correct?7910 piston is slab. No windows. There's also a bump in the exhaust floor in a 7910
You're still an azz pirate. LolI mean. ...hi. sorry
