Status
Not open for further replies.
Member
5:39 AM
turns over good and its a job to get to the key switch lol
Check at the coil as mentioned if no voltage try hot wiring. Also, some times freshly sanded points wont work until cleaned, like with a piece of paper, the grit gets in there and doesn't let them make contact. Not always, sometimes.
6:39 AM
the positive side of coil is on engine block side
Member
5:39 AM
i can get my volt meter on the nut for the coil thats not a problem i can always get my other tractor there to unload the logs but i didnt want to bother anyone today
This is of course is assuming you already kicked/hit a time or two.
Status
