- 2:42 AM
- Mar 1, 2016
- Mid-Georgia
Lmao...!!It will be returned to sender
Brother of mine has a 345...it ain't never checked up, and it's a firewood cutting nachine.A 345 is pretty much a 350
You will need the bearing cap peace to switch heads the 345 is like a clamshell. Then go from there I got a jred 2145 that was switched to a 2150 by @t4driller I sure he could point in the right direction and @tree monkey did something like this too but I can find the threadI got a question for the husky guy's. Is the 345 similar to a 346 as far as upgrading and such? If they are any good I can have one that my grandpa does not use anymore.
You will need the bearing cup/ cylinder riser out of a 350. Then you can put 346 or 350 cylinder on it. If going with the 350, use the 353 flat top piston. I've used a couple of the hyway 353 45mm piston and they have worked great so far. 2 i put with caber rings and the other 2 i put with the aftermarket rings that came with the piston. They all are holding up really good so far. Also make sure to replace the plastic intake boot clamp with a metal one. Also a muffler mod helps alot. Do a base gasket delete and it will be on the heels of a ported one.You will need the bearing cap peace to switch heads the 345 is like a clamshell. Then go from there I got a jred 2145 that was switched to a 2150 by @t4driller I sure he could point in the right direction and @tree monkey did something like this too but I can find the thread
So then it's worth grabbing it sounds like to me, the price is right free.I actually just sold one to my boss today. He asked me if I had any small stihl saws like an 024/026. Nope, just sold my last one last week. But I do have a husky 350. At first he didnt want it because it was a husky, but after handling and running it he really liked it. I think I have enough stuff here to put 4 more together...
Howdy Dallas. How's this workin an not flappin sheeeeeeeeeit workin out?evening rodidney hows you
That's the best price.. [emoji2]So then it's worth grabbing it sounds like to me, the price is right free.
I'm doing good, how are you doing? Sitting in the trailer at the moment cause it's raining.evening mike hows you
fixed it for you miguelI'm doing good, how are you doing? Sitting in the trailer at the moment cause im a slacker .
Me thinks you didn't work hard enough today lol.fixed it for you miguel
Here's one I just finished. Has a 350 45mm cylinder with 353 flat top piston, muffler mod, and some port work.
