peter92
- 12:09 AM
- May 19, 2016
- maryborough qld aust
be close to your bed time hahamorning peter hows you
down under hahaWhere you from Peter?
evening mark hows you
3 or 4 more hours lolbe close to your bed time haha
Keep your head down brother.Tornado on the ground a few miles away
what did ya get up to today 12.00 mid day here3 or 4 more hours lol
I've had good luck with the Hyway kits. Must've got a dud..Not bad.
workin on 372 and went to put seals in and wont fit!
HL supply gasket and seal kit,call them tomorrow?
Think i will just get oem and be done!
only earlyit is 909 pm here
I had a 288 kit that wouldn't bolt down with the carb bolted on.. Or even get the bolts in as a matter of fact...I've had good luck with the Hyway kits. Must've got a dud..
G-night JasonI'm getting tits up fellas...y'all have a good evening and night. If ya can't take it easy, you take it any way you can get it!
Yeah I haven't messed with the top end kits but the gasket/seal kits are OK.I had a 288 kit that wouldn't bolt down with the carb bolted on.. Or even get the bolts in as a matter of fact...
I figured the way my afternoon went, it would finish with a twisterKeep your head down brother.
Mis boxed? It is common.Pto side drops in case,flywheel side rubber on seal doesnt even touch the crank!
IDK??
Flip em around! LolPto side drops in case,flywheel side rubber on seal doesnt even touch the crank!
IDK??
Clint...... Or any old
Harley lovers??![]()
Oh man don't talk that way.I figured the way my afternoon went, it would finish with a twister
