Sty57
- 11:42 AM
- Jan 6, 2016
- Land of Cheese & Beer
Nope, just getting ready to roll out soon.You in Gawgia yet Brian?
That's why you buy it already on the bearing. 395 top end won't fit. Snelling bored a 390 to 56mm and used a 2100 thin ring piston in one.Dem nice saws. I had to do a bottom end on one for a customer this past winter and when I finished I ran a few tanks through it, I was impressed.
The clutch side seals are a royal PITA.
That bearing is $40-45 which sux but it is what it is.That's why you buy it already on the bearing. 395 top end won't fit. Snelling bored a 390 to 56mm and used a 2100 thin ring piston in one.
I think I paid low $30 from someone. Can't remember where now. I need to work on my 385. It's mostly all there just lack motivation.That bearing is $40-45 which sux but it is what it is.
If I pick this saw up today it'll likely get repaired and sent down the road. I already have the 385 and 395 so I probably don't need it.
Yep. I have a seal somewhere here. I've not tried putting it in a regular 6203 bearing. I may eventually do it.This saw originally had a bad seal, I figured easy fix, pop a new seal in and away I go.
After pulling my hair out and ruining one I got a second one and then gave Randy a call. He said to use a piece of 35mm film to make a sort of "ramp" to slide the seal into the bearing. That didn't work for me either.
I ended up replacing the whole bearing with seal.
If I remember right the seal was dang near $20 and the bearing and seal were a touch over $30.
Yeah that's what I pay around here.38.99 ish and 2 weeks from my dealer lol.
Good morning Jason how are you todayMorning sawheads.
Morning BrianMorning guys......
