- 12:52 AM
- Feb 5, 2016
- grafton wv
Afternoon Jake how's you
Good afternoon Jake, how are you doing? Are you happy with how the Homelite did?made a video of the homelite in somewhat big wood.
need to dull the felling dog some it doesn't bite in the bark so hard.
yeah but that felling dog is to sharp.Good afternoon Jake, how are you doing? Are you happy with how the Homelite did?
sweaty and full of sawdust.Afternoon Jake how's you
Some 80 grit will take care of that. Did the d009 fit?yeah but that felling dog is to sharp.
i didn't check but i did mix a bottle of 30 + yr old homelite oil i had to try at 32:1 it SMOKED like hell but worked fine.Some 80 grit will take care of that. Did the d009 fit?
can was starting to leak it was a 16oz metal can of it.Was that jug of oil already opened or did you waste something you could have sold to a collector
Neat saw Steve. That thing run 3/8?Sharpened up the chain on the P20 and gave the carburetor a little tweak. Also rigged up a chain adjuster from a Husqvarna as it was missing. Ain't quite right but did the trick for now. Cut up a little bit of wood to try it and it cuts good. Was not prepared for the wood chips coming out the top of the clutch cover instead of the bottom. See where it laid out the sawdust on the popple log.
Was/is a very nice gift from Brian, I like it a lot and is going to be a permanent member of the antique fleet.
Good evening Steve, how are you doing? I have not had one of the smaller p series saws, so I have no idea why it leaves those trails.Sharpened up the chain on the P20 and gave the carburetor a little tweak. Also rigged up a chain adjuster from a Husqvarna as it was missing. Ain't quite right but did the trick for now. Cut up a little bit of wood to try it and it cuts good. Was not prepared for the wood chips coming out the top of the clutch cover instead of the bottom. See where it laid out the sawdust on the popple log.
Good evening Clint, how are you doing tonight?Good day to you Mike
Ready for a cold beer and some good food. Chat with you guys, then watch some fire works.Good evening Clint, how are you doing tonight?
