- 3:25 PM
- Feb 5, 2016
- grafton wv
lol i see it
lol i see it
The 305 in the SB has dished pistons that are flopping around in the bore.....compression on that turd is nearly non existent. Plus.....Edelbrock 1406 not Q-jet.That's cuz it doesn't have enough compression to pop back through the carb.
Plus, quadrabog and stuff.
The distributor is pretty loose. It might have backed up enough.......should have it timed better then
your ford is barely able to make enough spark to ignite the plugs
But.....no working choke. I figure it lean popped.
theres your problem a *s-wordty edelbrock made for a 4 cylinder *s-wordbox not a v8The 305 in the SB has dished pistons that are flopping around in the bore.....compression on that turd is nearly non existent. Plus.....Edelbrock 1406 not Q-jet.
lol flop youYou had Dallas' attention at "flopping".
My Ford has the same carb.theres your problem a *s-wordty edelbrock
Sounds like a Steak and Eggs diet inbound...Welp. I'm going to stay away from bread, pasta, and taters for awhile. As if life wasn't sucky enough......
lol thats why i said itMy Ford has the same carb.
I like the Q-Jet.....and the Carter AFB, which is an Edelbrock 1406. I also like the Holley carbs. The trick is that a fella needs to be a little bit smarter than the carb. LOLlol thats why i said it
original carbs on ford sucked so they was changed often on them
people dont like the quadra jets but they was alot better carbs
so now you are calling me dumbI like the Q-Jet.....and the Carter AFB, which is an Edelbrock 1406. I also like the Holley carbs. The trick is that a fella needs to be a little bit smarter than the carb. LOL
This pussy wouldn’t lose sleep at night if I put you in a hole and buriedAnd you’re a pussy smh
I’d make you dig your own hole tooThis pussy wouldn’t lose sleep at night if I put you in a hole and buried
But did the Flux Capacitor get damaged?The Bubba's square body popped back thru the carb last night and caught on fire. He got it put out, but it melted the accelerator pump plunger.
That's never happened to my Ford.
