3browns
- 11:06 AM
- Oct 18, 2018
- Fishhook, Alaska
Its a big inch and a quarter. As opposed to a small inch and a quarter...32 mm ?
lol 25.4 mm per inchI think that is two feet.
And none of that *s-word makes senselol 25.4 mm per inch
So not near 2 feet
I just didn’t understand why the 32mm measurement unless he meant 32cm then it’s about 2.5 cm per inch and that would be about 13 inches
Supposedly easier to use as everything is divisible by ten, so they make things 32 commie units, which is not divisible by ten. Stupid commie metric system.And none of that *s-word makes sense
What this guy said. Fugg the maths. Unless @JoeDirt is doing the computationsMaths!!!
I got too much chit here. I ain't packing all this stuffs upI heard Elon designed it himself.
I'd move.
Yes sir. Thats the hole size for the European hinges. But us Mericans just use a 1 3/8" forstner bit..32 mm ?
What is model 94 in metrix?
explainYes sir. Thats the hole size for the European hinges. But us Mericans just use a 1 3/8" forstner bit..
I got my dads ancient 94 in 25/35 WinchesterWhat is model 94 in metrix?
I gotz one with a Weaver scope
My dad bought the 30-30 I have in 1977I got my dads ancient 94 in 25/35 Winchester
Not even gonna try to work that out in Commie Metrix
Forstner bits drill a flat bottom hole. Go 1/2" deep on the back of the cabinet doors and the hinges slide right in. 3/16" brad point bit works perfect for 5mm shelf pin holes alsoexplain
Forstner bits drill a flat bottom hole. Go1/2"12.7 mm deep on the back of the cabinet doors and the hinges slide right in.3/16"4.765 mm brad point bit works perfect for 5mm shelf pin holes also
so nothing to do with actually laying out cabinets just the hinge *s-wordForstner bits drill a flat bottom hole. Go 1/2" deep on the back of the cabinet doors and the hinges slide right in. 3/16" brad point bit works perfect for 5mm shelf pin holes also
Yes. But the Blum hinge machines or cnc routers have line boring heads that drill 5mm shelf holes 32mm apartso nothing to do with actually laying out cabinets just the hinge *s-word
