Loony661
462’s 4-LIFE
1:45 PM
Winona County, MN
Spark or no?
No spark, and not sure why yet. All the switches (ignition, kill, and tether) are working properly. Battery is good. Spark plug is new - although I haven’t tested for continuity of it yet. It’s possible I got a bad one.
JugHead27
I'd rather be called gay
3:45 PM
NS
Yesterday I decided I better get the boys little Predator 50 4 wheeler going. Of course the battery was dead. Wouldn’t take a charge either. Ran a town over and got a battery, filled and charged. Still won’t start. Fuel was old so drained and flushed fuel system, removed carb and cleaned. Still no start. Pull plug - wet. Spark plug was old anyway so run uptown and get a replacement. Still no start - and no spark.. Not much to these things, either gotta be the coil, or the rectifier/regulator..
Take the plug out still attached to coil and set it against grounded metal and turn the engine over. Should be blue spark
Loony661
462’s 4-LIFE
1:45 PM
Winona County, MN
Yep already did that - that’s how I realized that I wasn’t getting spark.
I have an in-line spark tester also, that I usually use, but wouldn’t work for this style of plug end.
