Lnk
Stock Chainsaws do not suck!
7:40 AM
East, TN
I bet property is high there.
Why should there be any different? Not sure how anybody could get into farming these days, would be on the treadmill for a couple generations at least. Rant over.
I think this heat is getting to me. I never get cold, but I might trade some of that for being able to work in this heat.
Dream
7:40 AM
Elberton, GA
Just came out to the truck to get some water.
Glad I'm on the inside today.
Y'all that aren't please find some shade periodically, and keep that water going down.
Ive had heat exhaustion years ago, and ive never been the same since.
Once you go too far, you cant take it the way you did before.
Dream
7:40 AM
Elberton, GA
Heat plus humidity is the kicker Larry.
Only place ive been that was worse was on a crane over the "wet end" of a paper machine. Thats what Hell is made of. 140+°F and actual clouds of hot steam that burn your throat and lungs. About 15 minutes is about too long to hang out.
6:40 AM
I was building a chimney chase on a roof several years ago, got way too hot, and nearly passed out. I never was quite the same.
Sounds like a sweat lodge.
stihl livin
Do the Dallas
6:40 AM
Upper Midwest
Been there myself. Had to wear an ice vest and climb scaffolding to repair a rain leader. 30 minutes from start of climb to needing to be back outside to cool off was all you had. Once gloves were sweat soaked it was hell climbing back down as it would just burn your hands. Told the boss we need to wait till they are down to finish.
timg
7:40 AM
Keystone State West
True that guys.
Approaching that status just before lunch. Glad my truck AC works well.
Break time ZZ.
JugHead27
I'd rather be called gay
8:40 AM
NS
Yep, wet bulb temperature, when it’s humid enough that your sweat won’t evaporate(despite glaring sun), you run high risk of heat stroke.
hoskvarna
6:40 AM
Iowa
Figured out the issue with the Camry AC. Worn out relay contacts. Of all the times it could F up. When we are stuck in traffic in weather over 100
Always [emoji2959]
Sent from Hoskey Hills
  • Like
Reactions: Lnk
Kiwioilboiler
346 Pic Examiner
11:40 PM
Marsden Pt, NZ
How do you like the tooling?
Why the red sealant. Thought you were a blue hylomar advocate?
BTW, Clean that work surface LOL. Don't know whether that's a plumbers table or saw table.
The dentist case set is the business. Still need to have a few spacers and washers about tho.
There's no red sealant. Think that hue is a reflection off the overhead tool lockers.
Hylomar Blue still here.
Nope, then someone will think it's a shelf and place something there in my way.
I'm back to Dirko.
Care to elaborate?
Morena you other diks too.
Lnk
7:40 AM
East, TN
I worked in corrugated, first as a maintenance man, when the lifting racks of the double backer broke and the machine was down, we had to go under the 350 degree vessels and replace a gear in the rack. Way too hot. 175 psi steam heats to 377* F, that's 192*C to you metriculated people. Needless to say, it is hot under there.
The wet end of a paper mill is the same. Awful. Makes me appreciate the heat we have here now. It could be worse, right?
