- 9:38 AM
- Jun 5, 2016
- Northwoods of Wisconsin
That's pretty cool
Was surprised at the weight of it. Right up there with an 038.
That's pretty cool
How long is the bar?
It looks like it would clear noodles like a mf'er.
Well friend. I can walk you through a induction leak down test. You will need a regulated air supply, heavy plastic bag, and soapy water spray. Komatsu T&A proven. LOL
Thanks for tips. I have access to a smoke machine and failing that radiator pressure bungs. Combining that with a bit of experience finding punctures in tyres should cover a physical leak in the boost system. It's tuned so I need up to 30psi. It only faults on a long hard uphill pull, so I suspect a hairline crack or something. Full throttle acceleration madness on the flat doesn't bother it.This thing is the shiz.
Different size "balloons" to seal off exhaust, intake ducts, etc.
Works great for finding induction and exhaust system leaks.
For once, a GM special tool that actually works...
View attachment 334403 View attachment 334404
Probably better power to weight than an 038 too.
@Mastermind @redline4
Milwaukee
Got it from a Storage wars guy down the road a piece.
Electronic, well that could get interesting.
Might just have to buy myself an obd dongle to live monitor it.
When did you move to california?
LOL.Friday night, If I get another piece of Easter ham warmed up in the microwave I'm going to the bar.
Was up there myself today. From 8:30 this morning to 6pm. Ripped 10 sq today and re decked after replacing some rotten rafters. New decking is 5/8'' Oscillating *s-worde Board. Prepped it all in water tight with synthetic paper. Ready for material delivery on Mon.I got on the roof for awhile. Just about passed the *f-word out from the heat. Must still be dehydrated from the marathon bowel movement session.....
I would do whatever I had to to make that work again if it were me.
Also, if that truck were here it would be considered rust free. Consider that when repairing the body. Dennis Carpenter has panels that come right off of the old forms he bought from Ford.
Milwaukee
Shingles went up AGAIN. They're just over $45/bdl here.
I have stripped one of those dashes.The boys almost have it ready to fire up.
Should be driving it around in a day or two.
Will probably still use the better cab, just change the dash so the ac stays.
Very cool.
I had a 74 F150 4x4. Body was beat up, so I bought a donor. Same truck, just 2wd.
Also a factory AC truck.
Word of advice. Wear gloves when you take the screws that hold the dash pad on out. There is what feels to be a roll of concertina wire up under there..
They all do. Cabs and car tubs are stamped pieces of metal, spot welded together. All else is bolted/screwed in.The dash itself does unbolt from the cab if I'm looking at it correctly....right?
