Dream
12:37 PM
Elberton, GA
Ok, you must be over 10k gvw. There are different rules for that. We do the DOT physicals in case we tow a trailer, but under 10k so no log book or rules, sort of. You do the crane stuff right?
Yep.
Chebby 5500 HD with 11' utility bed.
Stay away from the DOT crap, its a PITA.
Overhead bridge crane service.
We inspect, repair, modernize, install.
All that good stuff.
timg
12:37 PM
Keystone State West
It's actually not as bad as you would think. The *s-word they give you to prep will make you propose to the toilet, but it's totally worth it.
Just like Ryan said totally painless as you are twilighted. I've done two here in the past. The prep is the worst and the anxiety of not blowing a wet one on the ride to get the procedure done was it for me. Let's have lunch!! LOL!!
sawmikaze
12:37 PM
steeltown
I literally gave up the night before and put a pillow on the sink and just sat on the toilet the rest of the night.
Johnmn
11:37 AM
Minnesota
Aren't you young to have that done? Or does it run in the family?
  • Like
Reactions: Lnk
Johnmn
11:37 AM
Minnesota
I had it done at 35, the doctor said with all the pre-cancer I had in me if I would've been one of those guys that waited too long I would've been fukked.
Makes sense, I have family history of prostate cancer so they have been watching my levels since 35 as well.
cus_deluxe
terms of service violator
12:37 PM
Michigan
Kiwioilboiler
346 Pic Examiner
4:37 AM
Marsden Pt, NZ
On todays episode of “ask the dealer mechanic a question” : what would make stabilitrac, abs and trailer brake service lights come on all at once, 2016 6.0 2500. Kthanx
If it was my Ford I'd say low resistance Led trailer brake lights Custer, but since it's not...
redline4
I'm huge in Japan
11:37 AM
Rosholt Wisconsin
Anything pertaining to the ABS will do that.
Wheel speed sensor, steering position sensor, etc.
Going to need to get codes out of it first, then go from there.
cus_deluxe
12:37 PM
Michigan
Tried, maybe it was the chitty scanner my neighbor had, but it didn’t show any codes. I’ll try with a different one
redline4
I'm huge in Japan
11:37 AM
Rosholt Wisconsin
I see that quite a bit on the newer global architecture stuff where the serive writers try to diagnose stuff and their chatty code reader will only give them 1, or none, and there can be more set.
If they all came on together, I'd assume a wheel speed sensor issue.
They are all high impedence sensors now too, so you can't just ohm them.
GCJenks204
"Special Buns"
11:37 AM
Winnipeg, MB
Apparently bananas are the critical item for the blizzard of 22.
Two stores and the one commonality in both was no bananas…
I didn’t need and wasn’t shopping for by the large store nearest us usually has about 24ft of them and it was empty or stacked with grapes…. Noticeable change for sure.
