6:23 AM
... and what do you use to lay out all the cuts... A square.
What is the first thing done when the walls are done put up, check for...square.
Why then does the hardware store sell framing, rafter, T, sliding, fixed squares for?
How is the chop saw on the job normally set up? 90° square cut. Even has a place to go right to it.
a square doesn’t make a wall plumb and level lol
Lnk
Stock Chainsaws do not suck!
6:23 AM
East, TN
Nothing like a nice level, plumb, and square night's sleep. Going to be 52 today. Off to the wordle! Don't work too hard today, make sure y'all do some slacking.
Easier when you know the rules.
Wordle 233 4/6
Member
5:23 AM
a square is a tool for cutting of the lumber
If you are setting walls a square has nothing to do with it
Square only helps when on horizontal plane
As in a floor or ceiling
I never said a mfing thing about a walla walla, everyone else did. I would hope you used a square cutting the boards down to size when using a skilsaw for an example. Laying out window bucks you draw a line with a ...square. To cut stairs out you use a framing... square. In every mfing carpenters pouch is a speed... square. Once you install sheeting on walls and roof it holds the building ... square. if you shift one walla to one side or the other, the building will be out of... square.
Level plumb and square
