ayoungtexan
I tell a lot of lies
- 5:55 PM
- Apr 15, 2020
- Dallas, Texas
Good evening fellas
Your biggest problem in Emanuel Co is that damn sand...Sweet deal.
Those arent cheap.
They went up for the Dixie Chopper I have here. Last set I bought was $60.
That thing EATS blades. Lots of dirt, rocks, and sand here, plus the blade tip speed on that thing is REALLY fast. It'll suck the gravel up out of the driveway...
This guy has one acreSweet deal.
Those arent cheap.
Quest to you PB to usJust so happens I'm trailer trash meself.
This one has been HEAVILY modified now, but it still came here with axles.
That water supply line is a generic form of "quest" piping.
The New Pex stuff is way more GOODER.
Also, it had standard switches and receptacles. They were cheap, and have since been replaced. All circuits WERE 15 amp, with 14 gauge wire, except the dedicated circuits for washer and refrigerator.
Ive upgraded everything except a few lighting circuits I cant get to up to 12 gauge wire.
what are you eating? Or what was you eating ?No hate. None at all. Been there muhself. A man's gotta eat.
Agreed. Almost as bad here in Elbert county though.Your biggest problem in Emanuel Co is that damn sand...
Seems like a little overkill, but to each there own. 5 acres here. Mostly dirt and rocks.This guy has one acre
That was a 60 grit flap wheel on the ole Iron Horse special 4 1/2" Makita angle grinder.I use a Dremel 400 XPR or a Dremel 4000 with course drum wheels and three-foot flex shafts to re-sharpen my blades. Rarely will I use one of the 4” angle grinders. I’ll vice ‘em horizontal, and I’ve got a helluva lot of better control with the Dremel set-ups. A couple of these blades I still re-sharpen have been around since summer of ‘16. But I did just order two new same Rotary blades for the Husky push mower.
Thats called a rototiller Ed.I set my mower deck 1" into the dirt.
These cut just spectacularly.
View attachment 258576 View attachment 258577
*f-word lawns. I ain't got time for that.
LOL! Ive had that happen. Takes a while to mow having to go back over the stripe that the center gap didnt get.Those blades are still good.
The ends are still square and no splits/cracks.
When your 42" deck only cuts 36" then it's time to replace.
Hell, I got a little over half an acre here...home, double driveway, all concrete through two sets of double gates and a single person gate, at the head of the driveway, tied back into the back patio concrete, plus an angled pour all the way beyond the shop person door to get in the shop and let the two shop roll-up doors open. Home and all the concrete sucks up half what I got. I don’t even *f-wordk with my riding mower any more...to much of a PITA to move my truck in front of a set of double gates closest to the house, then I got a bass boat behind one set of double gates, a utility trailer behind the other set, in the backyard...to try and get the rider through. Too much to negotiate...by the time I move *s-wordt, make room to get the rider from the back to the front...I done got half the damn front and sides cut in the same amount of time with the push mower. Ain’t even no sense in that *s-wordt walking that push mower through the single/person gate, and hittin’ it runnin’.This guy has one acre
I have a soft spot for the trashy girls. The troubled ones. Gotta be clean but tattoos, hair spray, drinking problems, etc. I've been rehabbed for a while but I understand.what are you eating? Or what was you eating ?
i was kinda asking for pictures lolI have a soft spot for the trashy girls. The troubled ones. Gotta be clean but tattoos, hair spray, drinking problems, etc. I've been rehabbed for a while but I understand.
Blade balancer, meh...drive a 12d, 16d penny nail level in the side of one of your workbench framing. Same thing...That was a 60 grit flap wheel on the ole Iron Horse special 4 1/2" Makita angle grinder.
Same deal with the vice.
Cant find my damn blade balancer, so I had to use my finger this time.
That reminds me, my little Dremel 3000 wouldnt work last time I tried it. Was running fine when I switched it off.
