Dream
- 9:58 PM
- Aug 27, 2018
- Elberton, GA
Dont need to apologize for that. Looks good compared to what I did on that 350 muffy.Not my best brazing. The pipe is thick compared to the muffler. Makes for uneven heating.
I gas welded it. Same problem. Muffler was way too thin for the size filler rod I was able to find. Next one I do, I'm going after a smaller diameter filler rod and probably a smaller torch tip.
Either that, or invest in a cheap tig rig.
I can run a diversion off the engine welder on the truck, but it would probably be about the same result. Not able to fine tume the heat down low enough to keep from melting the muffler.
