Dream
- 12:50 PM
- Aug 27, 2018
- Elberton, GA
It is POURING in Athens GA.
you’ll make themLast time I checked in we where hatein' on dodges. Should still be in my opinion but here is a little something for the dodge boys.
What's happening Mike?Good morning fellas
Not much. Sup with you John?What's happening Mike?
Probably just up the road from the camp ground we be inz.Hoe tell
The fukk is wrong with you?Last time I checked in we where hatein' on dodges. Should still be in my opinion but here is a little something for the dodge boys.
Oh my gosh dude.
Thats the race Randy. Musta used Dominator. Causes rust and corrosion. Says so on the bottle.Case porosity like a mfer !!!!!
Was there water in the pan?
Cork sackin, mfen, spinless coont that fork is.No. And these don't really have a pan. The cases come together and there is a valve body cover on the side.
This whole ordeal is a total clusterfuckk.
Vehicle was towed in, "won't move unless gas pedal is to the floor".
Ok, yeah, it binds like crazy. Raise it up, transfer case leaking, less than half of the fluid in it that should be, shot with metal.
Tell Service manager and he asks if that the only problem. I say, I dont know, I cant exactly drive it and I sure as hell cant drive it if I remove transfer case..
He sells transfer case as they are non serviceable.
Well, that didnt fully sure the binding issue, and in typical management fashion, tossed my under the bus, then backed it up over me, then drove off into the sunset. So, here I am with the transmission out and apart...
Probably K-2....Holy hell.
Yamascuff maybe?
