- 2:14 AM
- Mar 7, 2019
- Keystone State West
Youngstucky. Nice and close to home, sleep in, home early, as long as no other fires break out. How bout you?Pa or Ohio today?
Yer done in here Monkey…You misspelled Dodge.
Looks like a postcard there Gary
If I needed a full size 3/4 ton or larger truck, a regular cab long box Godzilla powered Ford is exactly what Id get.They are huge because of the dohc, actually physically larger than a 460, but for has the new 7.3 gas with a stand alone computer for Godzilla swaps
Sounds fancy there John Hackinroe.Gamma Progression ST II...6-point mount system, dual fixed clamp, linear spring tension/lock out racquet (tennis/racquetball/badminton) stringing machine.
we already knew you was gay lol
Back in Shadyside for a couple of days then back out by the airport.Youngstucky. Nice and close to home, sleep in, home early, as long as no other fires break out. How bout you?
Get to work Joe. Quit slacking.
What's it used for? measuring the revolutions on the motor for servicing?So this shaft was worn out.
Got a new one made, and gave it some "enhancement".
Works much better now, and able to reach a bit farther.
Id say its a confidence booster of nothing else. I know, its kinda slim, but it fit just right.
View attachment 305285 View attachment 305286 View attachment 305287
Tells the variable frequency drive how fast the motor is going. Used as a form of overspeed control. Simplest answer.What's it used for? measuring the revolutions on the motor for servicing?
That makes sense. I haven't seen something external like that before.Tells the variable frequency drive how fast the motor is going. Used as a form of overspeed control. Simplest answer.
I think there is an off-road float kit for that. I think I installed one on my bronco. I think....cp4 is what those years come factory
Cp3 is what most uses
the truck I built had a edelbrock carb and intake
When you would put it on the side of a hill one side would starve for gas and the other was flooding
It was a 600 just like that
Rep for you Jughead.
I was actually told by a few of the older guys that built mud trucks the Holley didn’t like angles and the edlbrock was better. And I’ve always liked at least 2-1/2” pipe with thrush turbo mufflers
Damn encoders......So this shaft was worn out.
