Dream
7:42 PM
Elberton, GA
@Dream
Double lip seal in that there leaking tiller.
Hmm.
Might want to get that checked out.
Also, make sure the vent is open. Some have a rubber plug stuck in from the factory to keep ot from leaking if its turned upside down in transit.
Most folks dont bother to pull them, then it builds pressure til it finds a weak link.
redline4
I'm huge in Japan
6:42 PM
Rosholt Wisconsin
more than likely
how is that done
The numbers on the left side are programmed into the ECM with the scan tool.
That somehow tells the module the flow rate of the injector so it can individually control the pulse width to each injector so they all flow the same fuel per fueling event.
6:42 PM
You are now a mechanic, and an electronic engineer.
6:42 PM
I'm just a dumbazz with a couple wrenches.
I beg to differ.
I went to community college in 81 - 83 to be an ASE Certified wrench spinner. Today's automobiles blow my mind. Just looking under the hood I'm like......F-That.
You're a damn super hero Ed.
Kiwioilboiler
346 Pic Examiner
12:42 PM
Marsden Pt, NZ
I'm on my phone but it looks like a QR code there too Ed? Can just scan it?
Saw Collector
OPE Member
7:42 PM
Here
Hmm.
I pulled the vents when I was giving it the once over b4 firing ut up.
