41FanForLife
- 9:46 AM
- Apr 23, 2020
- Don Martin's House
quit wearing hoodies slackerAnd apparently the dryer works as a dust collector too. Washed my hoodie from Saturday and found this mess in the lint trap. View attachment 292056
When you stand around and do nothing ,you need one to stay warm.quit wearing hoodies slacker
was there frost on or snow on the ground? if not you didn’t need a hoodieWhen you stand around and do nothing ,you need one to stay warm.
GeniusDoes it have a front pocket?
My wife won't throw any of mine in the washer until I turn it inside out and hit it with compressed air.
I have a *s-wordty Carhartt one I wear often dealing with wood. Pocket was half ripped off anyway, so it got complete removed. Problem solved.
I would move!Mornin'View attachment 292057
I was out until 9pm after cutting trees for a neighbor
Started cleaning saws
And went to bed
Snowed a bit.
72 and sunny but we hear the storms coming from PA. It's snowing in Pocono 120 miles from here if that helps you out
Just pipe that smoke back to the intake. If it has pressure it will be fine as force inductionHere's one from yesterday.
Came in with a 02 sensor slow response and intake airflow system performance codes.
Smoke tested the induction system and it's building serious crankcase pressure...
Looks like I'll be doing some pistons..
EnjoyMorena money makers and chip launderers.
Headin in. More drizzle and 12c. Yay.
Keep safe ay.
Vega's from the 70's were fun in the 80's with no cylinder walls left in them. Good stuff
What gives up in these honeys? Rings, pistons or both?
Update, or same again?It already has a turbo.
Pistons fracture between the ring lands.
Can't even see Dan's saw underneath it this time!And apparently the dryer works as a dust collector too. Washed my hoodie from Saturday and found this mess in the lint trap. View attachment 292056
That really sucks. Has GM made a revision to the pistons for these, or do the cracked ones get replaced with same thing?It already has a turbo.
