USMC615
Fapper Fi
3:53 AM
Mid-Georgia
Morning chainsaw fuel mileage aficionados.
I wonder if a Piltz ms180 filled with 87 e-free weighs more than one with 87 e-10?
At 46.7:1 fish oil mix.
I've often wondered if the oil aficionados when mixing, allow the bottle to stand inverted in the spout of the gas can for about 24 hrs or so...allowing the residual pre-mix that clings to the inside of the plastic bottle to finally get 'in da mix.' Can throw off some tenths/hundredths ratios no doubt.
2:53 AM
Much better than earlier. I submersed myself in good music and tore into a saw im going to practice porting on. Cylinder on crank case this time. Numbers all recorded. Just have to figure out how may thousandths of stroke equals degrees and I can start the process.
Degrees of crankshaft rotation will not be equal to x amount of piston travel in all parts of the stroke. Near 90° the piston will travel much farther than at 0 or 180.
my bed is 8 feet wide and 104 inches long
I'll be hitting you up for pointers on building the headache rack. Were gonna pull the old bed off, do the exhaust, brakes, and u joints, then start on the new bed.....gonna be awhile. Everyone knows I'm slow.
Saw Collector
OPE Member
3:53 AM
Here
For a second I thought you were going to ask how many thousandths is a Sharpie...
I should have known better, you like to burn things up for “science” not to rip people off.
Not sure what that means lol. Anywho, I'm learning to port. No intentions on blowing *s-worde up but.....
I have some help behind the scenes to bounce my ideas off as I learnz.
