WANTED NOS 038 Tank, 041 Super 48mm Jug and Piston
bulletpruf
6:54 PM
San Antonio, TX
Fellas -
Trying to keep my 038 Mag all OEM/NOS. Looking for a NOS tank. One on it is functional, just faded and beat up.
Also have a 041 that I want to convert to 041 Super. I'm guessing it's basically a jug and piston swap, but if there's anything else to it (carb? muffler?) I'll want those bits, too. NOS or OEM is fine on the jug. Piston would have to be NOS or perfect used.
Thanks,
Scott
how57
It’s a city! Not a smoke!
9:54 AM
Weed Ca.
Fellas -
Thanks,
Scott
I have a used piston and cylinder off a 041 super. I have the cylinder studs also. image.jpgimage.jpg
jockeydeuce
9:54 AM
BC, Canada
Just helped another fellow make this conversion.
Besides the P&C and studs, the muffler and gasket are different and a different base gasket
bulletpruf
6:54 PM
San Antonio, TX
Thanks, that's good info. I'll probably do a muffler mod on the stock muffler, but will have to find some pics of the Super muffler first. And base gasket delete is likely so different gasket is not a problem.
Scott
jockeydeuce
9:54 AM
BC, Canada
Scott
Scott....The bolt pattern where the muffler bolts to the cylinder is wider on the Super....Totally different muffler, FYI.
