need suggestions on big saw.
Rcbeau1911
OPE Member
9:51 AM
florida
have tons of trees down from the recent hurricane. have 5-6 large 4-6' diameter live oaks that have fallen. I need suggestions on a saw with enough torque to drag a bar of that size.
this is most likely one of the few times I'll ever need to run something this big. was thinking a 660 with a full skip chain.
if you have something for sale shoot me a message as well.
Rcbeau1911
OPE Member
9:51 AM
florida
easy enough to find any suggestion on chain? been told twice now full skip
Ryan Browne
8:51 AM
Wisconsin
So, a 6' diameter tree is gonna need a 36" bar at least to get through it, huh? Yeah, I'd want a 661 or 395 if you can swing one. Otherwise a 660 would do the job for a little less cash.
As far as chain, semi or full skip would be good. Any of those saws will pull a 36" bar with full comp chain, but you'll have to be a little more light handed if you're running a stock 660. Also, skip or semi skip is nice because it has less teeth to sharpen.
Be careful with those big trees out there. A 6' diameter chunk of oak is gonna weigh a LOT! Make sure you know where that mass is gonna go if it shifts.
Rcbeau1911
OPE Member
9:51 AM
florida
luckily have a loader to catch the off cuts. and ya definitely don't want any of the volunteers messing with it.
Chainsaw Jim
Con Artist LLC
6:51 AM
Springfield Oregon
Is resale a factor? If so then the 880 will get you most your money back... and fast. Those things sell faster than any other model I've ever watched, and not at discount prices either.
Other than that I'd say a 395 will be a good option.
Rcbeau1911
OPE Member
9:51 AM
florida
nope looking to buy used
MarcS
8:51 AM
West Central WI
Great advice. I like to cut up the large trunks after somebody else does the brushing and runs out of saw. They are challenging and damn dangerous, especially if they pile drive a lower level limb into the dirt and the bulk of the trunk is held off the ground. Lots of wedges, an extra saw to cut out of pinches, maybe a tractor to pull things around, and really pay attention to where you cut and what is changing as you work on it.
My large saw is an old 111s but recently picked up a 2195 that is my new favorite.
3:51 PM
A healthy Dolmar/Makita 7900 will pull a 36" full comp 3/8" chisel B&C setup buried in oak.
Even less of a problem if You use skip chain.
This saw is also great fun in smaller diameter logs.
I am talking stock saw, only mild muffler mod on mine!
This is my Dolmar PS-7900 with 36" 115DL 3/8" chisel B&C setup, granted the loop was a home made "sorta-skip".
The piece of wood was a little over 40" long and got noodled into slices.
My Dolmar PS-7900 didn't miss a single beat.
Just making a suggestion.
Yes, a 90+cc saw might be better suited for said task, but You won't be wanting to use a saw that large and heavy for anything smaller.
I often use my PS-7900 to dismantle an entire tree, felling, limbing and bucking - great fun!
What I wouldn't give for a couple large diameter logs/trees to have fun with.
I've got an itchy trigger finger, and my girls really need a good workout. ;)
Cracker Boy
Fl cracker
9:51 AM
Florida
What part of fl you in i use my 044 more then any saw i got if i need big i use my 064 .theres actully a pretty good looking 064 on ebay right now iwas watching till i picked up another 064 builder cheap to rebuild for myself.there within 1 lb of an 046 460 more torque more h.p. they are my go to saws that and my 361.i live in central fl welcome to the forum
