Need some help with a Husky 44
av8or3
3:15 PM
Waleska,Ga.
Which slot to use for the Woodruff key?E34828D4-8018-44F3-A099-AF1664D68838.jpegAnd how to remove this oil pump? I have run screws into the threaded holes and tried to pull but no joy. 78F0391A-9F76-4DB2-A9C4-AD0E521AAF02.jpeg
Thanks in advance.
Jim
Disciple of Monkey's
2:15 PM
The letter above the appropriate keyway should be the first letter of the name of the ignition style used I believe.
The two threaded holes are for jack bolts to push the pump out.
@Tor R can you confirm?
timg
3:15 PM
Keystone State West
You will need to rotate the crank also to unmesh the worm.
av8or3
3:15 PM
Waleska,Ga.
Alright! I’m moving again thanks to you guys. :zpong:
I still don’t understand the keyway thing though. ( I jacked the oil pump out , just like you told me). Do I use the one with the letter over top of it ?
2:15 PM
They both have a letter, no? If not my idea uis bunko, if so, what ignition coil does the saw have? Maybe this is the idea, might be not so much, just something I have seen in old saw's before, when electronic ignitions first came out and the saws came either way.
@Tor R might have some more direct insight than I can give.
av8or3
3:15 PM
Waleska,Ga.
I set the flywheel down over the keyway marked “P”.
The saw has a blue “Preflux” (not sure on the spelling) coil so , what the heck. If it doesn’t run there , it’ll run in the other slot for sure.
Thanks for all the help guys!
Tor R
Novice, Leg model #2
9:15 PM
Mandal
You 100% correct, Steve.
I cant remember what coil the P setting is for.
Farmchuck
3:15 PM
Nepa
I need a side cover with brake handle for one of these saws if anyone has one. Thanks.:)
av8or3
3:15 PM
Waleska,Ga.
Here it is fellows. Nice little saw. When you fill it up it reeks of gas because the little umbrellas (vents) built into the caps leak. Have run about a tank thru it. So far so good. Has a hole in the fuel line right where it connects to the carb, is sealing for now but will order line on Monday. Oh, I almost forgot, it turns out the slot marked “P” was the correct choice for the flywheel installation. image.jpgimage.jpgRuns good too. I hope he’ll approve of the brake. His other side cover was toast and didn’t have one. But this was a $25 deal at my local dealer so I couldn’t pass it up.
