Mtd rear tine tiller
Buckman
OPE Member
11:17 PM
North Carolina
So recently I've acquired an older MTD rear tine tiller. The machine itself is in great shape but needs a motor. Went to pull the old one off and the 5hp briggs that was on it has two shafts. I have no experience with this type and I'm having troubles locating an easy replacement. Any ideas or advice?
Thank you!
MarkEagleUSA
11:17 PM
CT
I think the 2nd shaft is for reverse...
ammoaddict
11:17 PM
Granite Falls, NC
I have one of those tillers. Yard machines by mtd. I have only replaced the drive belt. Didn't even know it had two shafts.
Sent from my moto g(7) power using Tapatalk
ammoaddict
11:17 PM
Granite Falls, NC
Thank you!
You may be able to download a manual online. At least an IPL maybe.
Larry B
11:17 PM
SW ohio
The second shaft is the camshaft. It is used for reversing the tiller. Briggs no longer makes engines with the camshaft PTO. You can fit a new engine but you won't have reverse. Or you can find a good older 5hp briggs and fit the PTO camshaft and sump cover. Some 5hp engines have a sleeve bearing on the crank and some have a ball bearing on the crank. The crank bearing must match the sump cover.
Buckman
OPE Member
11:17 PM
North Carolina
