MS660 MMWS Cross Top End
12:21 PM
Very happy with the way the 066 I put one on runs. The Chinese 660 I have one on still needs more testing, but compression is way up there.
It is great that they come with Caber Rings, and the piston is lighter than OEM.
Often it seems the cylinders need a little work on the bevels, and sometimes a port needs a bit of clean up.
12:21 PM
I think the case capacity on the 064 is a tad small to utilize a 56mm unless your gonna cant with it.
I have a magII but I think Ill stick with a 52 or 54mm on my Brucey saw.
you have to paint it pink for bruce lol
Glock37
12:21 PM
Monroeville Pa
The cross topend is 54 mm with the 064 bolt pattern us 5 mm longer bolts because the base is as thick as a 066 cylinder
