MS660 clutch side bearing and crank help
flyingdg
OPE Member
5:13 PM
Utah
I would like to know if someone makes a clutch side bearing for the 660 that is all metal, not the metal with the plastic cage bearing. Also is there a rod kit for the 660 crank? not the full cranks that are out there. Thanks DG
Moparmyway
Its just a saw
7:13 PM
In a meeting
The rod and crank are an assembly thats not easily assembled or taken apart, thats why you have to purchase them as an assembly.
flyingdg
OPE Member
5:13 PM
Utah
That's what I thought, just hoping that there was a rod kit. In some of my race bikes I've had all the bearings in the engine isotropic polished. I would like to do that to the main bearings, big end bearing and pin. DG
Moparmyway
Its just a saw
7:13 PM
In a meeting
With the right resources, you can accomplish that
7:13 PM
Falicon crank
