WANTED ms460 Crankcase
Trader history (4)
jacktheripper
Papa Squat
6:00 AM
Wyoming
Well I am suspecting that the case on my 460 build has developed a leak due to the bearing seat separating from the magnesium.
Anybody have a matched pair of case halves?
redline4
I'm huge in Japan
7:00 AM
Rosholt Wisconsin
Don't rule out just the half you need either if the price is right. I built one from mismatched case halves and they lined up perfect, although some dont..
Which side do you need? I know I have a couple ugly 046 halves, just don't recall which side.
jacktheripper
Papa Squat
6:00 AM
Wyoming
It's the clutch side case half that I need. I just want to be sure that the halves match, like you said.
Woodwackr
6:00 AM
ID
What is the best way to differentiate 460 vs 046 cases?
Woodwackr
6:00 AM
ID
Screw caps vs flip caps. Thats the only difference as far as I know.
The ones I have are all stripped so…🤪
The one 044 is easy to tell but I’m not use about the 46s.
Flying_Dutchman
8:00 AM
MI
I might have an 044 case if you want to find a crank and build a hybrid 🤷
MG porting
5:00 AM
Wa
Just get online and buy a crankcase.
MG porting
5:00 AM
Wa
That's what I'm doing here. It's hard to find genuine stihl cases, if you weren't aware. If you know of something that I don't, please let me know.
The 046 and ms460 was and still is a very well used saw here in WA so finding a good used OEM case would be tuff there's nothing wrong with the aftermarket cases I've rebuilt a few ma460s using aftermarket cases the only problem doing so is there's no vin number unless you spend the extra money and buy a new OEM case.
Woodwackr
6:00 AM
ID
I have 4 different pt#s for cases.
1128 021 0700, 704, 0760 and 0762
What it what?
Is there a thread that shows the subtitle differences between the 1128s?
I only have a 461 so have nothing here to compare 044 vs 046, 460. I’m pretty sure none of what I have is a 441…too new for the pile of carcasses I bought.
Mad Professor
8:00 AM
Northeast USA
There is a thread on "the other site/AS" trading post. Guy has new and used 460 cases.
Not sure if OK to post this here, or links? If not delete the post. Just trying to help.
MG porting
5:00 AM
Wa
There's 440 and 460 and yes they are different. I'm sure you know the differences between the two saws??
