Huntaholic
- 6:36 AM
- Sep 17, 2018
- Tennessee
Well live and learn as they say! I ordered a gasket set for a ms460 simply because I couldn't find one for a ms461. Here is what I found out: seals appear to be the same, crank bearings appear to be the same, crankshaft appears to be the same, the cylinder gasket and more importantly the case gasket is definitely DIFFERENT! There went my afternoon chainsaw repair therapy session. I got the bearings seated on the new crank and got the crankshaft assembled to the flywheel side of the case and the seal put in, but that was as far as I could go. Oh yeah, I also got the caber rings put on the meteor piston and the piston slid into the cylinder.
