- 11:58 AM
- May 11, 2022
- Virginia
So this is a second thread for the Ms440 to keep the two saws separate to avoid confusion. This is all my first attempt at sling rebuilds/repairs of this level so thank you all in advance for your help. This saw seemed more promising than the 460 at first but she surprised me a bit. I’ll upload all of the pictures. Besides for needing some TLC the main issue I found is a leak at the clutch side of the crank. But it’s not leaking at the seal, it looks like the actual crank itself is leaking. Is this normal? The crank itself and the bearings feel great for being this old and is definitely due for a new piston and cylinder cleaning. What’s the deal with the bubbles on the crank? Also does anyone make a good aftermarket crank or should I always go oem?
Big bore cylinder kits since I’m already this far into it? Thank you all! My case splitter and seal puller should be in this week. Right now both saws and all the parts are soaking in my parts washer so hopefully this weekend coming up I will clean and split the cases.
