SELLING MS391 piston up for grabs
SawDoc441
11:48 AM
Temple, GA
Anyone need an imperfect 391 slug? I'm putting one back together that had a bad crank bearing. There are a couple of lines in the side of the piston, but it isn't too bad. I'm re-using the cylinder as-is. If you are rebuilding a scored one on the cheap, this is your ticket. It will likely run for quite a while. I get cost on parts, so I decided to replace it because I can. Parts have about 10 minutes run time (bearing failed on first tank of fuel). Anyway, free OEM 391 piston, rings, pin & (used) circlips. Shoot, I'll even send it in the box my new one came in. You pay shipping.
Sent from my SM-G900P using Tapatalk
michaelmj11
10:48 AM
Starkville, MS, 39759, USA
I may need one. I have a 391 I haven't seen in over 12 months (rather long story) and it is in pieces at the dealer, but was initially in for 0 compression. It was supposed to have had all new OEM parts shipped out by Stihl. .... but I hope it has been finally evaluated by the mechanic by now.
