Tinkerer Carver
- 2:37 PM
- Apr 27, 2021
- St Louis
Since I’ve already ground on this one, I was thinking performance mods as well. I was thinking port match to where the intake boot sits, port match the exhaust, widen the port on the muffler. Also, for the base gasket delete, do you just use RTV? Or could I measure the squish with a new gasket and have my machinist buddy mill off the difference of the gasket?That jug definitely looks serviceable. I would stick a good meteor piston and caber rings in it, replace the previously mentioned common wear/air leak items of the impulse line, fuel line and intake boot, rebuild the carb and vacuum/pressure test it. This would be a good chance for some basic performance modifications if you were interested like deleting the cylinder gasket assuing it leaves enough squish, advancing the timing, and opening up the exhaust a bit or at least matching muffler gasket and inlet to the exhaust port outlet. And remember it's just a saw and you have plenty of "help"
Here is a closer pic of the scored area
