ms260 metal oil pump gear?
thompsoncustom
1:28 AM
iowa
hey was wondering if there was a metal oil pump gear out there for the ms260 instead of the standard plastic one.
I ordered a new one off fleabay but it doesn't fit I assume it's for the non adjustable oiler.
thompsoncustom
1:28 AM
iowa
haven't found a metal one for the adjustable oiler being made anyone know if there is a different metal one that will fit? If not i'll just order a another plastic one.
jmester
2:28 AM
VIRGINIA
Looks like plastic worm gear only for the adjustable oil pump and metal for the non adjustable.
thompsoncustom
1:28 AM
iowa
ya that's all I've found but didn't know if there was another metal worm gear from a different saw that would work, figured someone on here might know the answer to that.
2:28 AM
The adjustable pump has a nylon gear. There isn’t a metal one. The stainless one is for the standard oiler.
Changing to the adjustable/Clutch drive pump requires:
Pump
Worm gear
Large Protector washer (I think)
Crank Washer and sleeve
Clutch Drum-it’s different for the adjustable pump to engage the tang of the worm gear.
The black one above looks AM. I’d stay away. The worm for the 260 has a straight tang coming off of it. Not the usual “Z” bend at the end like other Stihl models.
thompsoncustom
1:28 AM
iowa
Pump
Worm gear
I was hoping to find a metal one for the adjustable oiler like the black one on the right. I have a buddy that could make me one i'm sure but not sure if it's worth that much effort.
thompsoncustom
1:28 AM
iowa
Can I ask why it has to be metal?
the nylon one failed, one of the threads looked smashed figured I wouldn't have that problem with a metal one. I just ordered an OEM nylon one so we will see how it holds up and if it doesn't I'll have one made.
Added: just looked at the picture and I see you can't see the smashed section but one of the threads got flattened/smeared believe it was on the middle thread.
2:28 AM
Make sure your pump piston is moving freely. A stuck pump will ruin your gear in quick order. The gear in the pump should rotate easily with your finger.
thompsoncustom
1:28 AM
iowa
Thanks for the tip would hate to put a new one in just to ruin it.
