- 4:13 AM
- Dec 3, 2015
- Banner Springs Tennessee
I ported a MS201TC for a customer in 2021....and it was good for him over several years. Then....it began to idle too high. The saw was equipped with a black solenoid, with a build date of 2019. Which means it was an M1 system. His local dealer replaced the solenoid with a green one....and the issue persisted. So...he sent it to us. First we vacuum and pressure tested....which it passed with flying colors. Checked to be sure that the carb was closing properly....and it was. The saw would not continue to run through a reset.....so we figured that it was the solenoid. I tried a new black solenoid, a new green one, and a new white one. No matter which one we used, the saw wouldn't complete the reset procedure. At this point I decided to shoot the parts cannon at it. I tore down a new 201 and tried a new carb with a white solenoid. No change. Then I swapped the coil. The saw ran as a new saw. Used the M3 reset....and it passed. Then I reinstalled the old carb....but with a new white solenoid. Passed the reset again. Took it to the woods and ran a tank of fuel thru it....no high idle.
You fellas that work on M-Tronic saw regularly....chime in here with your weird experiences. I'd like to create this thread both as a troubleshooting resource, and just a place to vent about the silly things we see.
