WANTED Ms 362 pull cord assembly
Fullkip
Timber Faller/Saw Porter/Hunting Guide
11:02 PM
Douglas county Oregon
Wanted used ms 362 pull cord assembly, missing cord or spring ok...
timg
2:02 AM
Keystone State West
If you are looking for a starter I have one for a 361. Not 100% sure of interchangeability. There should be some more experienced input here later for sure. Thx. Timg
Fullkip
11:02 PM
Thanks for the response. I'm not sure it would work either but it might. If it would fit what do you want for it?
Anyone know if a 361 recoil will fit a gen one ms362?
Fullkip
11:02 PM
Thanks JJ for the info...
So still looking for Ms 362 recoil...
dmb2613
2:02 AM
Randolph Virginia
they are hard to come by no one junks a 362 unless it is smashed
lehman live edge slab
Live Action
1:02 AM
Mn
I’ll look if I have one and also double check to see if they will or not for sure but 362’s and the ms311/391 share quite a few parts and the rewind might bolt up. I have a blown 311 at home and a 362 so after I compare I’ll let you know
Fullkip
11:02 PM
Hey thanks but I found one on fleabay... be nice to know though.
I still need a choke linkage and an air filter base. One for the hd2 filter...
Live Action
1:02 AM
Mn
Ok the rewind will bolt right up ones plastic and the other is mag but they fit and work. Guts have the same part numbers even. Need to look but may be a bunch of parts that are common between the 362 and the 311/391
