eonk
Active OPE Member
- 12:13 AM
- Apr 19, 2025
- Wadsworth, Ohio
I recently tried to start the saw and the pull cord wouldn’t come out. I removed the cord and it worked fine. When looking for the problem I tried to remove the chain sprocket and it won’t budge. I suspect that the bearing broke and the pins are jammed in the sprocket. Any suggestions on how to remove the sprocket? Yes, I did remove the e clip and the washer.
