Ms 250 assembly question
merc_man
merc_man
4:55 AM
southern ontario
Put new crank seals on the ms 250 and wondering if i should put some gasket maker where the seals sit. I figure it wont hert to?
Keith Gandy
Maxima K2 40:1 87 Pump Gas
3:55 AM
Provencal, Louisiana
Dirko is what the factory uses. Motoseal. On the outside corners where the crankcase halves meet at the seal is where it will leak 9/10 times. Loctite 515 or 518 will work also
merc_man
merc_man
4:55 AM
southern ontario
I used motoseal. Let it set.for a couple hoirs then pressure vac tested and all good now. Never looked like any sealent on seals from before
merc_man
merc_man
4:55 AM
southern ontario
Also so i know for next time how do you guys get the seal over a groove on crank shaft. I was carfull but afraid of wrecking the seal.
jake wells
no longer here
3:55 AM
ky
coat the outside of the seal with sealant and go around the entire mating surface of the cylinder and the bottom of the clamshell half with sealant.
Motorhead
Cantre Member
4:55 AM
Tampa Fla.
If I have one that the spring keep coming out I put moto seal on the lip that holds the spring,let it set a while put some oil on the crank and carefully twist it into place
