Ms 170 / 180 Adjustable Carburetor Swap
Vintage Engine Repairs
10:14 PM
australia
I got my hands on an ms 170 and here at sea level it was bogging badly off idle and max rpm were between 15,000-15,500 rpm. Running 50:1, a dull chain and aging diaphragms wouldn’t end well, it’s just a disaster waiting to happen for the future customer, especially here in Australian heat. Hopefully the new owner enjoys using.
The local dealer let me rummage upstairs and let me have a used WT215 for free, I just needed to install a new main nozzle.
It was a good oppertunity to do a short video at the same time.
EFSM
9:14 AM
Extreme southern IL
These saws leave the factory notoriously lean. When I rebuild the carburetors I enlarge the main jet slightly with a jet cleaning tool I made into a drill. Great if you could find a Walbro to work.
10:14 PM
australia
Yes same here, I’m right at sea level so it’s about as bad as it gets. Good call just drilling the main jet out slightly its a shame there isn’t a simple way to make the L drillings larger.
Sloughfoot
7:14 AM
Norcal
I got a WT215 and a pop up for my ms180 a while back. Soon as it gives me a reason I'll swap out the carb and advance the timing. I've since learned that a pop up piston doesn't always increase performance and sometimes hurts it, so may not bother doing that. Anyone in here put a pop up in a 180/170?
Zee33
10:14 AM
Pennsylvania
I don't know if this makes any sense but my boys 170 was having idle and bogging problems too. I started looking at it and here as he ran the saw , the bar and chain were tightening up causing the saw to bog. Not sure what kind of adjuster you have , his was the dial type. What we ended up doing is putting duct tape over the adjuster dial to keep it from moving.
I know this seems odd but it worked for us. Then we richened the fuel after the saw was warmed up with a full tank of fuel
Wonkydonkey
Plastic member
2:14 PM
Sussex, UK.
That saw was a bit to kleen 🤔😉
But still a very good & concise video
10:14 PM
australia
Thanks! I gave it a good clean before the video :)
I think the owner must have only used it a couple times. It’s a shame it wasn’t a 180, but it will make the next owner happy!
Edit, just noticed you’re in Sussex, I now live in Australia but I grew up in Sussex! Best place in England ;) well, not really but it’s nice!
Wonkydonkey
Plastic member
2:14 PM
Sussex, UK.
Yes the 180 is definitely a better saw.
They wake up a bit with 1/4 to 1/3 off the fixed keyway and also like the exhaust opened up.
But if your selling it, it’s probably better to keep it stock.
I was born in brighton and still live here 😉👍
Sloughfoot
7:14 AM
Norcal
Dial adjuster on mine does the opposite. Chain starts loosening or won't tighten when the screw that holds the adjustment wheel thingie on the bar backs itself off. Retighten and it's good as new, for a little while.
Zee33
10:14 AM
Pennsylvania
My opinion is to just get a ms211 . You won't regret it. I bought a used one for $150 and have never had a single problem . I got it from a guy that was going to use it for a climbing saw but found it too heavy
10:14 PM
australia
Ha crazy, I was born and lived in Shoreham for 24 years before moving to Australia!
I’ll modify it yes, I plan to do another couple videos on the saw. Keeping an eye out for a 180 though lol. I may even stick a 180 engine in, they have a bunch upstairs at the local dealer lol
JKNW
7:14 AM
Washington
One of the best upgrades I did to my 170 was to swap the chain adjuster to the side adjuster for an MS211 makes it a much nicer saw to use/maintain.
My 170 has been fooled around with a bit at this point, WT215, foam air filter and some restrictions removed in the air inlet, muffler mod and advanced timing have it running like a whole different saw. I've got a 180 engine sitting on the shelf to swap in at some point, probably going to add a pop-up to that before it goes in.
Chainmale
3:14 AM
Tasman New Zealand
Same mod's I've done to mine, plus steel bucking spikes and 12" bar running .050 so I can run full chisel non safety
Wonkydonkey
Plastic member
2:14 PM
Sussex, UK.
Oh,
This thread got my cad going, I thought I got over it 🤦‍♂️🤷‍♂️
I saw this saw and next thing it’s mine 🤪
I guess, when it arrives I will give it the molesting it needs
Here’s An update for you guys.. I don’t know if I,m happy or sad 🤣🤣🤣
Well guess what,,, the fugging courier has lost the parcel 🤷‍♂️👎
Sloughfoot
7:14 AM
Norcal
Bought a Lil Red Barn pop up for my 180, but am having second thoughts because I read the extra weight negates the added compression on a small saw. You know anything about that?
Wonkydonkey
Plastic member
2:14 PM
Sussex, UK.
I'd say…..
Once you open the muff and swap the carb + a bit of timing adv.
btw, don’t forget the before & after vid
If you’re still wanting moar oomph. Maybe you should be the guy 😉 to show the advantages of a popup
I think it could work quite well, as the clamshell saws can have a large squish. So it could make good use of that space 👍
JKNW
7:14 AM
Washington
I don't know enough to know either way to be honest. If I do buy one I'll throw it on the scale vs the china 180 piston and see.
