- 3:04 AM
- Dec 26, 2015
- The land of pleasant living
p&v testing it today. Everything is good except the decomp. valve ,where the cylinder is cut into below the peak of the jug, leaks pretty good. Everything else is fine. What do you use to plug that decomp. Valve because a regular plug is too short? Everything else is fine that I know of. Also, took off the flywheel and it is double keyed (oops). Its got a dogleg type coil on it and the flywheel says 1203. Which slot do I put it in looking at the face of the flywheel? I think it goes in the right slot, but not sure. Any help is appreciated.
