SOLD MMWS Ported MS201TC $1000.00 Shipped
Trader history (5)
Stihlasaurus
12:45 AM
Utah
1:45 AM
They didn't change port timing and such or ignition timing? That piston didn't change your squish related work? I wonder if the piston is heavier? I think I have an older version, I have something special planned for it whenever I get around to it.
Everything is the same except the piston crown, and the combustion chamber design. The firmware is different, as the reset procedure is now the M3 process.
I don't alter the exhaust port roof height, just the width. The biggest change that I do is in the upper transfers. They use an insert that is epoxied in, and it doesn't fit worth a damn. I raise the uppers, and match the insert to the passages. The ignition timing is as far advanced as possible without causing a misfire under load from the factory, so I don't alter the flywheel key.
Well, sumbuddy cancelled the GTG, so no runoff. One reason why my 201t is on the back burner... and my straight pipe 2511t.
The way it's going here, we might not have it next year either.
Woodpecker
Sassy Madam
2:45 AM
It's just money.
True but I gots to spend it on other stuffs... someday my friend.
Logsdendave
11:45 PM
Oregon coast
Those YouTube vids. Sure are impressive. I would’ve wanted this one, had I seen it before it sold. Oh-well I jest bought a saw. So maybe next time.
1:45 AM
I was able to get one more......it sold too. These are a hot commodity.
