jakeshi
- 1:54 AM
- Feb 2, 2019
- Richmond, VA
Being a MMWS what has been done to it? Help me understand the draw.
Ugh.
I'll make sure Dally sports his Stihl orange two-piece.Dallas and Jason? I'm sure they'd be truck models for you...
Do you run a different gas mixture?Cut squish and base, port work, muffler mod, timing advance, etc.
Then 50:1Do you run a different gas mixture?
Thanks for the input. If I get the saw just want to do what the boss would recommend. I have switched over to the Aspen 2 fuel and all my 2 stroke stuff and it really runs better I think. I also used Amsoil Dominator in the past with good results.
That is great knowledge to have.I had a customer call me yesterday with 562XP bogging off idle issues. Doesn't happen in the summer. I recommended that he try some premixed canned fuel. Winter blends really don't seem to work well in a high strung autotune saw.
Eliminating a common problem being fuel quality is a good thing to keep in mind. It's often overlooked.It was just something for him to try. May or may not fix the issue. But two ported 562s, both having the same problem....I bet on it being fuel related.
