Mill size vs bar size question
Whitty21
12:53 PM
Ontario, Canada
I have been looking at the new Huztl mills to try out, in canada the price just seems too good to ignore. I am looking at the 48" one. Problem is I have a 50" bar. Does anyone know if it will squeeze in there? otherwise I may be able to take the guard off and create a newer one on, or, just use my helper handle?
Thanks in advance
Whitty21
12:53 PM
Ontario, Canada
I know they van be shortened. My question is if a 50" bar will squeeze into a 48"mill. I know the extra 2" is just more unusable bar. I just don't want to buy a 48" bar while I have a 50" sitting here
junkman
Crush it
9:53 AM
pacific northwest
even with a 50 inch bar you will not have 48 inches of mill to use to use the whole 48 you need a 52 or 53 inch bar you lose some on moth ends from the clamps on the mill
11:53 AM
Unless I'm missing something here won't the 2 extra inches of bar end up by the power head ?
Whitty21
12:53 PM
Ontario, Canada
Yeah. I realized that after I posted my last post. Let's just say it was a long day at work today haha :goofy:
flying pig
10:53 AM
Grande Prairie, Alberta
I have a modded mill dedicated saw with no dogs and my mill sits tight to the powerhead, also my mill is set up so it is clamped on the center of the bar nose and with a 36" bar I still only have 34" mill width. I would expect without pulling your dogs and staying back from your tip you will lose at least five inches of mill width.
junkman
Crush it
9:53 AM
pacific northwest
Thank you, Brian.
In your opinion, could 75LPX be converted to ripping chain. I have a bunch of it.
I don"t see why not,i run chisel ,if going round i set the grinder to 10 on top plate and zero side plate,gives a smooth finish in my softwoods ,if i make the angles too aggressive gets kind of grabby and bogs power,
Wonkydonkey
Plastic member
5:53 PM
Sussex, UK.
Thank you, Brian.
Yeh, I did to some carlton chain
It was slow going, so I sped up. some of the teeth got a bit hot, but I only found out how hard they were when I came to sharpen the chain with a file. It was skating across
I had to get it on the grinder again to remove the hardened edge
flying pig
10:53 AM
I've found that milling with a couple different type of chains. It's almost like it work hardens or something. Stihl chains seem to do it a bit.
