- 6:42 PM
- Jan 21, 2016
- Missouri
Ok fellas, my 4300 has sat since last year and when I went to start it, it started and ran only at an idle. Once I touch the throttle it stalls and dies. One pull restart and same thing, touch the throttle it dies. Figured it a carb issue. Pulled the carb and there was some gunk in the screen. Nice, cleaned the carb and put it back on. Same thing. Messed with the carb some more and made no difference. Still starts, idles all day long, but touch the throttle it dies. Put a new sparkplug in it for grins, no change. Pressure/vac checks ok too.
So I order a original ZAMA carb. Put it on and no change. Starts, idles all day, dies if you touch the throttle. I've had two huskys do something similar and an echo blower do the same thing and all ended up being ignition coils. Haven't heard anything bad about these ignition coils. Have heard of goofy flywheel things with the dolmars but the saw ran great when I put it away. Anyone have a good way to test the coil and flywheel before I dump a ton of money on an OE coil or flywheel?
