Looking to buy felo 1000 Volt safety bits
zillah
Active OPE Member
12:32 PM
NZ
Dear folk
I am looking to buy a set of felo 1000 Volt safety bits (insulated power bits)
Code:
https://www.felo.com/en/innovations/1000-volt-bits.html
But I couldn't find on ebay , amazon ,,,,,etc,,,,,,last resort I might need to ask the manufacturer
Can you please help me if there is any other reputed (quality) brands at market ? ,,,,I am based in New Zealand
The one that I found near me is only PH2,,,,I am after set (PH1,PH2, Slotted,,,etc)
Code:
https://goteborgsaventyrscenter.se/product/dzml672mjvpp/10pcs-1-4-hex-shank-screwdriver-bit-insulated-non-slip-cross-head-power-tool-70mm-150mm-ph2-long-reach-electric-screwdriver-bit
Code:
https://sydneytools.com.au/product/xtorque-xib1502-2pack-150mm-ph2-insulated-tube-driver-bits
Thx
zillah
Active OPE Member
12:32 PM
NZ
Thx Czed
The link that you posted are bits for hand tools and i am after bits for power tools (impact drive) or they are called 1/4 shank bits
zillah
Active OPE Member
12:32 PM
NZ
Thx Czed for suggesting alternative
zillah
Active OPE Member
12:32 PM
NZ
I didn’t get chance yet to get one
mikegreen008
OPE Member
8:32 PM
Florida
Please let me know when you find one.
Sent from my SM-A022F using Tapatalk
zillah
Active OPE Member
12:32 PM
NZ
So i guess the question for me is What are you working on that needs 1000v protection but is rugged enough to be attacking with impact power tools?
Not necessarily to be rated 1000v as I work on DC power and every day I need to terminate 60 connections with battery terminations as backup for DC,,,,therefore I preferred to use power tool with insulated bits
Kiwioilboiler
346 Pic Examiner
2:32 PM
Marsden Pt, NZ
I like Wera screw-drivers, and they don't appear to make what you are looking for....but what about insulated bits from an inter-changeable screwdriver with the 9mm hex drive. Could then use a drill with a chuck and just set the clutch to suit?
https://products.wera.de/en/tools_for_electricians_kraftform_kompakt_vde.html
zillah
Active OPE Member
12:32 PM
NZ
stick a power tool chuck on the hex drive of the bit
Oh are you saying I can insert them into my impact drive (1/4 shank) ?
